Cabinet is not done yet.
You need to add the "prop" rod. You wont be able to raise the playfield, and hold it in the service position without it.
Prop rod clip, installs below the wooden block:
https://www.marcospecialties.com/pinball-parts/01-12352
prop rod:
https://www.marcospecialties.com/pinball-parts/01-4028
Needs a bushing for the pivot side:
the bushings are hard to get, I would ask around if anyone has a spare ( i dont or i would send it to you), or find something suitable at home depot.
(its mounted correctly on the right side of the cabinet in the photo)
There is a small hole in the prop rod to attach a ground wire.
This is an important wire. It goes from the rod, to the little bolt that sticks out of the AC power box.
The rod is fastened for transport with a rubber ring (white ring on it in the photo).
YOUR HARNESSES NEED TO BE SUPPORTED IN THE CABINET.
They are HEAVY and when the backbox is folded the connectors will literally be RIPPED out.
You will need 2 pieces 1 1/4" corrugated split hose 30" long, or 5 feet cut in half,
Or one 30" piece of 1" slit hose for the 2 cabinet harnesses,
"And" one 30" piece of 1 1/4" hose for the 3 playfield harnesses:
https://www.marcospecialties.com/pinball-parts/RM-27-08
https://www.marcospecialties.com/pinball-parts/RM-27-07
Once the slit hose is pushed onto the harness, and slid up as high as it can go, you need to secure it onto the backbox:
this is accomplished by using "saddle" type nylon tie anchors and 1/4" wide nylon tie:
https://www.amazon.com/dp/B09B8NY4SN
If you cant find the saddle anchors, I can send you a few.
I'd have to look but I may have a prop rod, but no bushing.
