Hi.
My AFM was working absolutely fine for a year (no electronic problems at all), until I plugged it into a socket controlled by a switch with a fader (I think it's a Lutron Diva). It still worked fine, until today. The light switch w/fader controls a pair of wall lights and a pair of outlets (you turn on the lights and adjust their brightness with the fader). Yesterday, when the fader was set low, my AFM did not come on. Then, I moved the fader up, and the machine came on. I assume I sent variable/increasing current through the machine. I switch the light off at night (I don't flip the machine's power switch off). Today, when I turned on the lights (fader all the way up) my AFM did not turn on. I have tried plugging the machine into a different socket. No luck.
Thanks.
