Quoted from BigAl56:Is the MPU properly switch optioned for Dolly Parton?
Yeah, 4 on 3 off 1 on. It is also blowing the 20 amp Gi fuse in coil test
IMG_1126 (resized).jpegQuoted from BigAl56:Is the MPU properly switch optioned for Dolly Parton?
IMG_1126 (resized).jpegQuoted from sullivcd40:Yeah, 4 on 3 off 1 on. It is also blowing the 20 amp Gi fuse in coil test[quoted image]
On the replacement rectifier boards, J1 is 9 pins because some later games used a 9th pin. Dolly does not use the 9th pin, so if you didn't key your J1 connector after recrimping, you might have plugged it in wrong. J1 is everything for the playfield, including GI and solenoids.
pasted_image (resized).pngQuoted from Knxwledge:On the replacement rectifier boards, J1 is 9 pins because some later games used a 9th pin. Dolly does not use the 9th pin, so if you didn't key your J1 connector after recrimping, you might have plugged it in wrong. J1 is everything for the playfield, including GI and solenoids.
It’s not plugged into pin 9 on rec board J1. It’s getting proper power on all the LEDs on the mpu and sdb and booting all the way. I also found for continuity between mpu j4 1-4 and sdb j4 3-6. I’m wondering if it could be a bad connector elsewhere on the mpu or sdb. I’ll also go ahead and re repin the rec board connectors while I’m at it. I’ve ruled out lamp, sound, and switches other than test switch by unplugging them all.
Quoted from sullivcd40:Dolly fires wrong solenoids in test
Detail exactly which solenoids are activating at each solenoid test so we can try to work out if there is a pattern in the error.
Quoted from sullivcd40:It also fires all solenoids to start a game.
Is the game playing the correct sounds/tunes?
Note, the solenoid select signals double up as sound select signals. These signals from MPU J4 (pins 1-4) first go to the sound board J1 (pins 1-4) then daisy chain onto the SDB J4 (pins 3-6) connector. There is a separate Solenoid/Sound control signal (MPU J4-10 to sound J1-8 to SDB J4-7 (Brown-Red wire)). This control signal tells the sound board and SDB who should accept the four select signals.
Quoted from Quench:Detail exactly which solenoids are activating at each solenoid test so we can try to work out if there is a pattern in the error.
The picture of the coil table shows handwritten actual versus expected in test. Sound is not properly functioning when plugged in. I’ve included additional pictures of the boards as well.
IMG_1128 (resized).jpegIMG_1129 (resized).jpegIMG_1130 (resized).jpegIMG_1131 (resized).jpegIMG_1132 (resized).jpegIMG_1133 (resized).jpegQuoted from sullivcd40:The picture of the coil table shows handwritten actual versus expected in test.
You've got 16 written next to the coin lockout and 17 next to the flipper relay, meanwhile there are only 11 coils total. Please clarify.
Quoted from Quench:You've got 16 written next to the coin lockout and 17 next to the flipper relay, meanwhile there are only 11 coils total. Please clarify.
16 is the number on the display when the coin lockout clicks.
Only 11 coils, but Stern/Bally didn't always used them in sequence; numbers would be skipped.
Quoted from Quench:These signals from MPU J4 (pins 1-4) first go to the sound board J1 (pins 1-4) then daisy chain onto the SDB J4 (pins 3-6) connector. There is a separate Solenoid/Sound control signal (MPU J4-10 to sound J1-8 to SDB J4-7 (Brown-Red wire)). This control signal tells the sound board and SDB who should accept the four select signals.
This is a great clue, I think I need to repin the sound connectors next.
Quoted from Coyote:Only 11 coils, but Stern/Bally didn't always used them in sequence; numbers would be skipped.
Stern yes, some of their games resolve the solenoid test number to the actual driver transistor number for convenience and go up to 19.
This is not the case with Bally and the game in question is Dolly Parton. Game only has 11 coils and so solenoid test only goes to 11 specifically testing each coil.
Quoted from sullivcd40:16 is the number on the display when the coin lockout clicks.
If solenoid test is going to 16, your MPU board definitely is not running Dolly Parton game code.
Your game select dip switches look correct. I'm guessing that maybe switch number 5 is being seen as On instead of Off resulting in the board booting instead as Night Rider. This can explain why you see 16 in solenoid test and why many solenoids fire when you start a game (Night Rider is a chime game). Flick that game select switch 5 on and off a few times and back to off to see if it resolves to Dolly Parton.
Quoted from Quench:Stern yes, some of their games resolve the solenoid test number to the actual driver transistor number and go up to 19.
This is not the case with Bally and the game in question is a Dolly Parton. Game only has 11 coils and so solenoid test only goes to 11.If solenoid test is going to 16, your MPU board definitely is not running Dolly Parton game code.
I tried toggling all game select switches a few times, plugged everything backed in, but the problem remains. I have another weebly in my big game that I can try swapping.
Quoted from sullivcd40:I have another weebly in my big game that I can try swapping.
Wait a few minutes. We will test your switches on that MPU board. I just need to create a diagram for you.
Quoted from sullivcd40:I tried toggling all game select switches a few times, plugged everything backed in, but the problem remains.
The voltages at the round pads above the game select switches should read as indicated.
Quoted from Quench:The voltages at the round pads above the game select switches should read as indicated.
I got 0 0 0 5 5 5 5 5 0. So getting 5v at the 4th pad from the left instead of 0 as indicated by your diagram.
Quoted from sullivcd40:I got 0 0 0 5 5 5 5 5 0. So getting 5v at the 4th pad from the left instead of 0 as indicated by your diagram.
That equates to Kings of Steel. It goes to 17 in solenoid test. Try flicking that 4th switch on and off a few more times. If no luck you may need to talk to barakandl about it. Big Game wants that switch on as well. Anyway you can use the MPU board out of your Big Game to continue testing Dolly Parton.
Quoted from Quench:That equates to Kings of Steel. It goes to 17 in solenoid test. Try flicking that 4th switch on and off a few more times. If no luck you may need to talk to barakandl about it. Big Game wants that switch on as well. Anyway you can use the MPU board out of your Big Game to continue testing Dolly Parton.
Let’s go!!!!!! Took a few more hard toggles and I felt that switch sorta pop into place. It’s was maybe sliding a little before. Thank you once again Quench! Also credit to Big Al, he was right from the beginning.
Hopefully an easy question here.
I need to replace the switch stacks on my Mr and Mrs Pac for the flipper buttons. But I cannot for the life of me figure out the part number. It's not in the manual, and I'm not sure which part number in the '82 parts book is the one I'm looking for. More worried about the switches that control the pac-maze than the flippers themselves.
Anybody know what part number I'm needing to order?
Quoted from northvibe:New pop bumper switch stack from Pbl for an ebd. The diode for the spoon I get; the extra diode were the lights go, is not technically used. Leave or cut out?[quoted image]
Cut out
Quoted from jsa:@Quench you are a truly phenomenal troubleshooter.
Thanks! The trouble shooting we did here with your Future Spa was pretty epic
What was the end result with the solar inverter?
Quoted from jsa:Quench you are a truly phenomenal troubleshooter. Always very impressed.
I second that! Amazing
Quoted from Quench:Thanks! The trouble shooting we did here with your Future Spa was pretty epic
The company that made it ripped the entire thing out on their own dime and replaced it with a modern and better electronics. Then a year ago I sold the house and moved to Michigan. Future Spa came with me. Of course!
It was amazing that the manufacturer read through our whole thread. They changed things as a result.
Now I use isolating transformers as a matter of principle.
Quench really is this best here. I had some crazy issue and he replied with some crazy thing to check that I thought "huh, no way", but of course he was right. Something I'd been chasing for weeks resolved in minutes.
Flip one solder lug to the other side for the lamp feature.
Quoted from woody76:can someone confirm factory star post size on bally's is 1 3/16?
What specific post.... They use both heights on most games depending on position.
Quoted from slochar:What specific post.... They use both heights on most games depending on position.
Its for a Dolly Parton. I do not have the game in hand yet and was wanting to order some supplies for the swap. I ordered 1 3/16.
Was 8 years old when I first started playing these awesome games and now I finally an owner. Added a nice Future Spa with freshly stenciled cabinet, nice playfield and have pushed all my modern games aside the last two nights to dig in! What a great game…played on location and in tourney for the past couple months along with many other Bally/Sterns.
Wish the backglass didn't have the flaking from previous owners but it’s been cleared.
Won’t try to ask too many questions as a noob to the group
Quoted from woody76:Its for a Dolly Parton. I do not have the game in hand yet and was wanting to order some supplies for the swap. I ordered 1 3/16.
You can view and download the parts manuals here: https://www.pinwiki.com/wiki/index.php/Bally/Stern#Parts_Catalogs
Bally games generally use 2 different height posts depending on if the post supports a plastic or not.
This page was printed from https://pinside.com/pinball/forum/topic/bally-as-2518-club/page/79 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
