On this stepper unit of mine the left target scoring unit under playfield got off track. When it is in reset, where should the bottom spring leaf be positioned?
I tried to match it to the right unit but am unsure. I have the position as shown on one of the first in line brass rivets. If stepped two strokes from the coil then it will turn clockwise and then the same spring leaf will be on the brass rivet for the number two light on the playfield.
Just asking if correct bc now the 10s relay is stuck on but I could have hit a switch by accident which is now another issue to resolve.
Would like to confirm rest or reset position, if some knows.
