Hi,
First off, thanks to all who have posted threads and vids regarding soldering.
I will be quite honest. I am not that sweet at soldering. Recently, my upper flipper stopped working on my Godzilla. Lifted the playfield and noticed that the yellow wire going to the flipper coil had somehow broken off.
Does this repair require de-soldering first with copper braid or the desoldering gun? And once clean, the wire can then be soldered on correct?
I guess my question is there is no way around doing a vertical soldering job i.e soldering with the playfield up and doing it semi-upside down, correct? I would just hate to drip all over the place. Or should I simply buy a new coil, so I can skip the de-soldering?
I watched many of the videos and all of them show the person sitting down in a comfortable chair at a large flat workbench, happily soldering away. OK, yes, I can do that. But with connections under a playfield, the art of soldering takes on a whole new dimension.
