(Topic ID: 354061)
Pair of Hayburners II Williams 1968
By scottacus
31 days ago
  • 16 posts
  • 12 Pinsiders participating
  • Latest reply 19 days ago by Miguel351
17
#1 31 days ago
Last November I picked up two barn find Williams Hayburners II machines and a Williams Derby Day head. The pins were stored on their backs so the back plates were beyond repair.
Because these were stored in an out building they required extensive cleaning in the ultrasonic cleaner with Simple Green.
The numbers on the score reels were shot so they were replaced with ones I made with my Cricut.
The horse unit was disassembled, cleaned and the leather washers were brought back to life with neatsfoot oil.
The machines were then put onto the test bench to make sure that they could be repaired before investing more time into the project.
I made new backs and used JB Weld two part wood restoration to rebuild the damaged parts of the cab and head.
The cabs and heads were then sanded, primed, painted white and then speckled with a speckling brush.
The artwork was projected onto card stock and stencils were made.
Green and black Dreatex were airbrushed onto the cab to give the soft edges that the original art had.
Legs were bought and the backglass were scanned, fixed in photoshop and printed on paper to test the reel openings as well as the light masks before sending off to have them printed by GameOnGrafix. Also new tempered glass was ordered because these were missing and the pins use an odd glass size so standard glass would not work.
GameOnGrafix printed a black mask layer as well as a top color layer for me. I’ve used them several times in the past for this.
The apron art was beyond repair so it was remade with Gerbermask and the Cricut with Createx for paint and clear coat shot on top.
The playfields were beyond touch up repair so one was a total repaint and the other only has the original two tone lettering so it was a 95% repaint. The pf’s were depopulated and cleaned.
The pf’s were sanded flat, clear coated and drop filled.
I made svgs of all of the pf colors (white, black, dark green, red, orange, light green and yellow) as well as all of the letter and numbering. Each color was then masked and airbrushed starting with white.
For two color numbers I sprayed the background number color, masked off the key line and then masked off these numbers when the area cooler was sprayed.
The main colors were then masked and sprayed.
Finally all the colors were masked and the main background light green and yellow were sprayed.
Any touchup key lining was then done.
Lastly the the pf’s were clear coated with Spraymax 2k. I found that by using halogen spots I could get the clear coat to cure in about three hours. The data sheet for Spraymax says that it can cure in as short as 30 minutes under IR light so these halogens must have put out a fair bit of IR as well as heat.
Here are some shots of the finished machines.
There you have it, four months of work in one post! I plan on bringing them to the Midwest Gaming Classic in Milwaukee the weekend after next.
#2 31 days ago
Fantastic work and thanks for sharing....
#3 31 days ago
This borders on necromancy... Nicely done!
#4 31 days ago
Incredible build log!
#5 31 days ago
Great work, and excellent explanations of your procedures!
#6 31 days ago
Holy crap... lot of work there. Nice job.
#7 31 days ago
#8 31 days ago
Awesome work! Some techniques I've never seen before.
Question on the apron (I'm doing the same one for my Solids N Stripes), how did you do the pink? Oversized letters/logo or simple larger areas of pink?
#9 31 days ago
I was afraid that the createx white/red/florescent pink mix for pink would not cover the black so on the first apron I laid down pink and masked off the letters and sprayed black. If you look closely at a Williams apron you'll see that some of the black is turning the pink to a slightly darker shade (Williams laid pink over black as best I can tell) so on the second I laid down the black and then sprayed the pink. That's how I would recommend doing it since it is easier and looks original.
Screenshot 2024-03-28 at 8.48.07?PM (resized).jpgScreenshot 2024-03-28 at 8.48.07?PM (resized).jpg
#10 31 days ago
I should mention that the key to all of this is Gerbermask. Bord turned me onto it and it is hands down the best masking material I've ever worked with. It is the perfect combination of just enough tac but not so much to lift paint, supple texture and excellent masking property. There is no way I cold have gotten as fine a detail as I did with vinyl.
The other thing is don't try to save solid black lettering. Just blow it out and repaint it, it is not worth the effort to save and the end result will be better.
#11 30 days ago
Quoted from scottacus:
These look wonderful. Can't wait to play them at MGC!
#12 30 days ago
One of the cool features of these pins is that you can play a two player game. Some of the other horse racing games that I've played like Nags only is a one player game. We can give it a go at the MGC!
Another cool feature of the .game is that the flippers zip open to give the rotating turret launcher a bigger arc to shoot from.
Lastly according to IPDB "'Hayburners II' is credited with introducing 3-inch flippers to the game of pinball in place of 2-inch flippers that were used since their introduction in 1947. However, Sample games may exist of Gottlieb's 1951 'Happy-Go-Lucky' as shown in its flyer, where the flippers appear to be 3 inches in length or longer."
#13 30 days ago
Holy. F-ing. Shit.
I enjoyed this thread. What an amazing and nice piece of work (x2).
#14 27 days ago
Did I miss it somewhere in this thread or in the other one? Did you mention what you used to cut out the stencils?
#15 19 days ago
Quoted from Miguel351:
or you can buy my licensed stencils here
https://pinballpimpstencils.com/hayburners-ii/
#16 19 days ago
I was asking to see if he used a Silhouette or a Cricut because I recently did that with my Spirit of 76 refurb for the bonus circles using just regular Frisket and it worked like a charm. If he used one of these machines with the Gerbermask, that's good info. Also, these stencils are just for the apron.
Your stuff is amazing enough as it is PinballPimp! Some of us just like the journey of doing it ourselves.
The Pinball Scientist
$ 12.00
This page was printed from https://pinside.com/pinball/forum/topic/pair-of-hayburners-ii-williams-1968 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
