I just acquired a Gottlieb Shaq Attaq and I am loving it. I am having an issue with both top flippers, however. They both seem to be blowing fuses (the top right one blows a 2A slow-blow near-instantly when in use) and the top left one took an amount of usage before it blew the 2A fuse. I took a look and nothing seems out of the ordinary. My only suspicion is that there is a short in at least the top right one (the one who blows out near-instantly). I took a multi-meter to it and I was getting ~1.4 Ohms resistance, when the service manual is looking for around 4.6 Ohms. Would this mean I need to replace the solenoid/cause the fuse to blow? The resistance for the left one that doesn't blow nearly as often was closer to 4.6, and to check I was doing this right I checked the working main flippers and each were within ~.2 Ohms from spec. The solenoids are A-26646 (Blue sleeves). I am also not 100% confident I am reading the expected resistances right, because they list two numbers (4.57/201). Any help would be greatly appreciated!
