The playfield is held in place by the side rails, bottom rails and the triangular plastics rails. Rails had been painted and all the screws cleaned. The screws go from the underside off the playfield, through a hole in the plexiglass playfield, and into the rails.
Unfortunately, there is a screw hole underneath the batting mechanism plate, so that needs to be taken off.
Really great job. Invaluable resource. I will reveal my Giants retheme soon. Pin blades came out nice. It is really looking amazing. You now can hit it up the "adios pelota ramp" and over the arcade and into McCovey Cove. You can also hit into the water out in left so, hey that's a good poke!
LEFT FIELD (resized).pngI decided I better make sure I can cut the holes in the bottom of the cabinet before trying to replace it. That’s gonna be the speaker hole, the hole for the power switch, and the 2 vent holes. At this point, I didn’t realize there is also a slot for the cards to fall out from the card dispenser because it was covered by the metal plate in the original cabinet bottom.
IMG_4969 (resized).jpegIMG_4970 (resized).jpegIMG_4971 (resized).jpegIMG_4973 (resized).jpegThis was the “Here we go moment,” that there was no turning back. I made a guide for the router to keep it a fixed distance from the edge and set my depth to 5/8th inch, the thickness of the bottom.
IMG_5180 (resized).jpegIMG_5185 (resized).jpegIMG_5186 (resized).jpegIMG_5193 (resized).jpegIMG_5195 (resized).jpeg
Quoted from shirkle:How is the bottom adhered to the cabinet?
That is indeed a problem I was gonna need to solve.
So after routering out the cabinet bottom I had 3 thoughts:
1.) There is a little groove that is in the cabinet sides that the cabinet bottom fits into. To use that groove, I would need to router out the top lip of the groove so the new bottom could sit on the groove lip. The problem is if I went that route, it would make my cabinet bottom too small. I was not keen on not so much cutting a larger bottom, but it would mean I would have to recut the speaker hole, power switch hole, vent holes and the card shoot hole. Groan.
2.) I now had great access to a damaged back corner that my Elmer’s glue job seemed a little inadequate.
3.) I started to consider getting a new cabinet made.
I have a friend who gets WPC cabinets made quite regularly. I asked him about a Slugfest cabinet and because it’s a totally different shape than a pin, it would be a custom job. It would have been about $2000…that’s a huge hit to the Slugfest restoration budget.
Because it would be months to get it done anyway, I decided to start by repairing the damaged cabinet corner.
Gotcha. I have a slugfest too and would love to restore my cabinet. It’s faded and needs some other minor work. Yet, if I could get a new one for a reasonable price, I might have considered it. But $2k is more than I’m willing to spend. Shame, as it’s such a fun game, especially for casual players.
I got lucky here a few times. My advice:
Hold the plate on the inside and screw in the leg bolts from the outside. When I did this, my plate was actually going to be too long and I had to trim it first before installing it or else the cabinet bottom wouldn’t sit flush.
I wanted to replace the original corner wood brace as it was all busted and the plate wasn’t laying flat with the old wood brace in there. I chiseled out the old wood brace and cut new ones. I found the best fit was cutting a piece of 2 x 4 at a corner at 45 degrees so each length against the cabinet would be 1 1/16”. That would make the hypotenuse of the triangle 1.45”. a2 + b2 = c2. Look at that. A little high school math.
IMG_5239 (resized).jpegMy plan was to re-glue the cabinet corner, glue the wood brace into the corner, then screw in the metal plate with 6 wood screws. Just before I did that, I got lucky because if I did that, there would be no way to put in the leg bolts. My advice: you have to drill the leg bolt holes in the wood braces FIRST, or there is no way to get the leg bolts through.
IMG_5273 (resized).jpegIMG_5274 (resized).jpegIMG_5275 (resized).jpegSo now I have to figure out how to keep the bottom in securely. The original cabinet bottom was in a groove and had these metal cleats in the bottom/side of cabinet. I had no idea how to install these, let alone where to get them. I thought about glueing some of those wooden corner braces to the bottom/side of the cabinet, or maybe metal braces. Finally I decided on the ol’ glue and screw.
IMG_5167 (resized).jpegIMG_9071 (resized).jpegTo get good contact between the cabinet bottom edges and the cabinet sides, I decided to fill the groove with wood strips I had from another project. These fit in perfectly. Some TiteBond glue and some clamping, and the bottom would be set for installation.
IMG_5455 (resized).jpegIMG_5456 (resized).jpegIMG_5457 (resized).jpegIMG_5458 (resized).jpegIMG_5459 (resized).jpegIMG_5460 (resized).jpegSo the plan is to use this glue along the outside edge of the new cabinet bottom and along the flat bottom of the cabinet that essentially frames where the coin box will go, and these screws through the outside bottom of the cabinet into the edge of the MDF board and hopefully not have the screws poke out. Technically, I do NOT think that is a run on sentence.
IMG_5688 (resized).jpegIMG_5693 (resized).jpegI predrilled and countersunk the holes all around, taped off the cabinet, mixed the epoxy and spread it on, screwed in the 2 1/2” screws nice and tight, then clamped. I probably should have gotten help because with the glue, there is no time to be dinking around. At this moment, I was glad the bottom piece was 3/4” thick instead of 5/8”.
IMG_5689 (resized).jpegIMG_5449 (resized).jpegIMG_5694 (resized).jpegIMG_5696 (resized).jpeg
I really appreciate and enjoy this thread. I’m looking forward to my own restoration hopefully this coming summer.
This is a little out of order, but was important for the cabinet restoration. My original plan was to take off the back door of the cabinet with all the boards which you need to do for decaling, and then put it back on after decaling. Unfortunately, the plywood was warped like crazy. I tried to think of ways to try to flatten it out, but in the end, the solution was a trip to Home Depot for 3/4” plywood.
IMG_9558 (resized).jpegIMG_9559 (resized).jpegIMG_9560 (resized).jpegIMG_9561 (resized).jpegIMG_9562 (resized).jpegIMG_9584 (resized).jpegWhat kind of epoxy did you use on the cpo? Did you sand it afterwards? I was contemplating making a flat cpo panel like older machines to eliminate the cracking issue but this is an easier option if effective.
I used this epoxy to fill the gap between the front bullnose of the wooden part of the control panel and the metal plate. I overfilled it slightly after tightening down the metal plate, the put a piece of painters tape across that gap running the length of the control panel to flatten out the epoxy before it dried. I didn’t sand at all because when I pulled off the tape, the gap was filled in and perfectly flat. I have no idea why the painters tape doesn’t stick to the epoxy.
BTW, it’s the same epoxy I used to glue the cabinet bottom on. Along with the screws of course.
This page was printed from https://pinside.com/pinball/forum/topic/slugfest-10/page/2 and we tried optimising it for printing. Some page elements may have been deliberately hidden.
