Quoted from Big_C_70092:Do you mean the board with three wires?
They r in the machine and have already failed
I guess it can’t hurt to attempt a re sawder but please advise on which joints and which sides of the board. I have back up ones coming in a few hours that I ordered as a precaution from pinball life
The legs of the LED are usually the culprits, however, I reflowed the pigtail leads as well.
Ok... what you need- soldering iron, wet sponge, solder, possibly a solder sucker or solder braid if you need to remove excess solder, swabs, industrial wipes or paper towel, isopropyl alcohol.
Clean everything, iron, solder, joint, board with iso and let dry.
Iron temp 750 degrees, Tin iron tip by applying solder while it just gets hot enough to melt the solder, then rubbing tip on wet sponge. This will leave tip nice and shiny if done right.
Immediately place tip on solder joint, trying to melt the remaining solder on the pad, liquifying it and getting the tip of the iron to actually touch the LED leg. Now wait just a momement... watch the solder around the leg and it should start bubbling due to residual flux in the joint. Take a small amount of resin core solder and apply it to the joint, little at a time, maybe all of a 1/8" to 1/4" of solder wire, just enough to flow through the boards cold side and create a filet on the hot side. If solder balls up on the leg, keep heat on leg until flows to cold side, or, remove the excess with solder braid or a solder sucker and add back new solder until joint is formed.
If the monkey fisted masked dyker has cut the legs off too close, you will have a hard time creating a filet, so a solder ball may be the only thing that will form on the hot side. Go with it. You have no other choice. Reflow second leg the same as first. Repeat for pigtail leads, especially if the dyker cut them too close as well.
Thats all you can do from a user standpoint. Reinstall if they work, test them by plugging the transmitter and reciever in and point them at each other with your hands before reinstalling, the red led will blink as you align and mis-align them if it is working and you will see it work if in switch test mode.
Clean off the flux residue with iso and install, should last more than 15 games, mine has.
Hope this helps someone.
BH
