I hate butane soldering irons.
I especially hate the jet exhaust that comes from those torches. I hate managing the direction of that jet vs tight spaces. I hate burned hands, singed wires, and coil wrappers with that campfire smell. I was seriously just one step away from replacing my butane torch with my Hakko 888 for field work - but man, that's a lot of bulk in my bag.
A friend of mine in the tech industry introduced me to an alternative. One that he could take on airplanes - as carry on. No pressurized cans of gas, no hot jet exhaust. Runs off batteries. I was skeptical - the last time I saw a battery powered "soldering" iron, it was one of those "cold heat" pieces of crap.
"No, really, try this."
Folks, I'm in love with the Mini (minidso.com) TS80 soldering iron. (I'll also talk about TS100 in a followup post).
The TS80 is a light weight compact 18w thermal controlled soldering iron.
- USB powered (requires QC 3.0); supply must provide 9v 2a
- Or off a static 9v supply (but see TS100 info later)
- Runs up to 400C active in 10C increments; with separate idle standby temp setting
- ~30 second warmup from cold
- wedge or conical tips; most kits you order have only one, but extra tips are easy to get
How well does it work?
That is the real question, isn't it?
There's a number of videos on YouTube for this; I'd suggest
In that review he illustrates soldering to a large ground plane; zero problems.
For pinball repair, I can say that reheating old solder on coil lugs, the solder melts like butter, and quickly. Quick enough that I'm no longer burning my fingertips from the wires conducting heat. I'd also use this for quick board repair, if I don't need the magnifying glass at the bench.
What does it come with?
.. Depends on what you buy. Not to sound flip, but there are a ton of vendors selling variations of this package, especially on AliEXpress (China's version of eBay). The cool part of this is it means you can pay for just the parts you want, and skip the parts you don't.
Instead, I'll share what to look for:
* TS80 itself, probably comes with one tip. If you only get one tip, I'd suggest the edge tip. There are great forum topics on Pinside about soldering.
* Power adapter. The big white adapter that some kits have will work in your service outlet.
* ESD ground strap. I'm only using battery power; I haven't used mine.
* Small case that holds two tips and the holder; but doesn't really fit the usb cable or brick. In hindsight, I ... didn't need this. I'm using a different case that holds my battery and other things. Most vendors sell this separately.
Powering the Iron
The TS80 expects to negotiate QuickCharge 3.0 (QC3.0) USB ports for 9v, 2a. You can also use a static supply.
Most kits come with a power brick brick. This will work in a pinch with your service outlet. You'll probably want a longer USB cable to reach the far end of the playfield.
I bought this for *battery powered* use. And for field work. I wanted a solution with as few hacks/adapters as possible. As such, I bought Anker's 26800 PowerCore+ QuickCharge 3.0 battery. https://www.amazon.com/gp/product/B01N3TVRP2/
PowerCore+ 26800 Premium Portable Charger with Qualcomm Quick Charge 3.0 (Aluminum 3-Port Ultra-High-Capacity External Battery) PowerCore+ 26800 Premium Portable Charger with Qualcomm Quick Charge 3.0 (Aluminum 3-Port Ultra-High-Capacity External Battery)
I plug the iron into it, and it just works.
Demonstration with Anker PowerCore 26800+ QuickCharge 3.0 Battery
It is worth noting that this iron does not support USB-PD (USB Power Delivery). If you have a USB-PD capable power source, you'll need an adapter. Perhaps "yzxstudio"'s ZY12PDN. It has a button. You plug it into your USB-PD source, hit the button to pick 9v, and then use it to power the TS80. My engineering friend does this, because he has several low voltage devices; the ZY12PDN is effectively a power supply adapter for all his devices. I personally don't want the hassle.
Third party yzxstudio ZY12PDN - Adapter for USB-PD batteries to provide selectable DC voltage
Your USB cable should be rated for charging. The silicon coated ones will also not kink so easily.
Docs and Firmware
I hope you can read Chinese.
I can't, but I made do with Chrome, with a plugin to handle translations (https://chrome.google.com/webstore/detail/google-translate/aapbdbdomjkkjkaonfhkkikfgjllcleb). You could also use translate.google.com and give it the forum URL; and view (badly formatted) translated paged. Even without that, you can probably find your way to the correct page.
To hopefully save you hassle, these are the links (as of April 7 2019).
- Forum page for firmware:
http://minidso.com/forum.php?mod=viewthread&tid=3202 - v1.07 firmware: Hopefully http://minidso.com/forum.php?mod=attachment&aid=NzE3OHw5ZGM5NmRjOXwxNTU0NjUxNzUxfDB8MzIwMg%3D%3D
- English Manual: http://www.minidso.com/forum.php?mod=attachmentaid=NzAzMnw3OTJiNzBhNnwxNTU0NjUyMDU2fDB8MzIwOA%3D%3D
- Unofficial mirror: https://github.com/TripleDogDare/ts80
Upgrading the Firmware
* There are two buttons on the iron
* Hold the one closer to the tip
* Plug in to USB on a computer.
* DFU3.45 should show up on the display of the iron.
* That acts like a memory stick. Copy the firmware with the .hex filename onto the stick.
* Wait for the filename to rename itself to .rdy, and disconnect.
My Final Kit
This is what's in my tool bag now; and all of it is packaged into the bag mentioned.
https://www.amazon.com/SainSmart-ToolPAC-Soldering-Intelligent-Complete/dp/B07H8D1PHH/ Iron, Tip, Power Cable, etc
https://www.amazon.com/NovelLife-Original-Soldering-Tip-Replacment/dp/B07K244Y46/ Cone tip
https://www.amazon.com/gp/product/B005C789EU/ Mini stand and tip cleaner
https://www.amazon.com/gp/product/B01N3TVRP2/ Battery - Anker PowerCore 26800+ with QuickCharge 3.0
https://www.amazon.com/BAGSMART-Double-layer-Organizer-Electronics-Accessories/dp/B01N21QFVN BagSmart case
In fairness, I bought the TS80 iron and tips from AliExpress - it saved me about $30, but cost me about 30 days. Evertything else I had.
The BagSmart bag was a gift, and it's intended for small electronics, memory sticks, etc. But it's working out great for me to keep all the soldering related stuff in one place - easy to get in and out of the tool bag (versus all the bits mixing like soup at the bottom).
The one thing I need to do next is come up with a way to pack "enough" solder, but in the BagSmart bag, instaed of having the spools running loose. I carry a couple sizes of solder, depending on whether I'm working under the playfield or on a circuit board.
Is it worth it?
That's entirely subjective. I was considering starting to carry my Hakko 888. Compared to that, it's worth it to to spend $100ish on the iron, extra tip, etc; and another $70 on a battery. I consider this a *fine* alternative to my bulky Hakko desktop iron or the butane iron.
I'm a fan of spending money on good tools that make better use of my time (and patience). I'm a person who will throw money at a problem, if it solves the problem. Of course, not setting myself and other things on fire from the butane jet exhaust is absolutely priceless.
I've shared this with a good friend who's much more frugral than myself. Runs the local pinball museum as a non-profit. He's been in this shared obsession for decades. He's got his own TS80 now...
